× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi RBS40V. Netgear sent firmware update
GreyBeard1948
I have an Orbi Rbr50 WiFi router with 2 satellites. One of the satellites is an Orbi Voice rbs40v. Netgear sent an email to upgrade the rbs40v but every time I try to update the firmware I get an error message. My Rbr50 firmware is v2.7.2.104.
Does the Orbi Voice need a firmware update by itself? I could use some help please.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi RBS40V. Netgear sent firmware update
You are on the current firmware version.
I know that there was issues over the last few days with the auto-update server but you're on the most current so you should be good.
Message 5 of 6
All Replies
Guru
What actual version is your rbs40v on?
Message 2 of 6
GreyBeard1948
The firmware version is shown as V2.6.2.4 on my Mobile Netgear application
Message 3 of 6
GreyBeard1948
Was reply incorrect? I just need to know why I keep.getting an error message when I try to check for new firmware. In the past when I Checked the firmware it would state I have the most current update or would tell me to update. Do the router and the voice satellite have to be on the same firmware version?
I am not good at this and really need some help. My WiFi numbers are fine as is everything else.
Message 4 of 6
Guru
Message 5 of 6
GreyBeard1948
Can someone tell me why when I try seeing if I have an update on my Orbi application I get an error message and not the message that your system is up to date? I do not understand what would cause this ad I have an excellent WiFi signal.
Thank you
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1683 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
