- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port forwarding does not work properly, getting a ERR_CONNECTION_TIMED_OUT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port forwarding worked fine on my older Netgear router I have at my regular residence but now I am working from my childhood home and, although I did the exact same thing to port forward on the router there (set up port forwarding at Advanced Setup > Port Forwarding / Port Triggering) I am getting a "ERR_CONNECTION_TIMED_OUT" message. I can get to the local LAN server (http://192.168.1.13/) fine and trying to go to a port I have not opened results in "ERR_CONNECTION_REFUSED" so it is is probably a firewall issue or a bug. I have tried authorizing port 80, 443, 2377, 4789, 7946, and port 1880 to no success. I have also restarted the router several times to no affect. I came across a few other people with similar issues in my search for an answer but have not found a good response.
This has eaten up way too much work time!
My router is a R6400v2, not a R6400v1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port forwarding does not work properly, getting a ERR_CONNECTION_TIMED_OUT
> My router is a R6400v2, [...]
Firmware version? Connected to what?
> [...] my older Netgear router [...]
Not a very detailed description of that device or its configuration.
> [...] although I did the exact same thing [...]
It's nice that you're happy, but, with my weak psychic powers, I
can't see what you did at either site.
> [...] I am getting a "ERR_CONNECTION_TIMED_OUT" message. [...]
When you do _what_, exactly? From where? As usual, showing actual
actions (commands) with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> [...] I can get to the local LAN server (http://192.168.1.13/) fine
> bug. [...]
You're doing that from a system on your LAN? So, we're talking about
some web server or other? Running on a system of some type at
"192.168.1.13"?
> [...] I have tried authorizing port 80, 443, 2377, 4789, 7946, and
> port 1880 to no success. [...]
Exhibiting the actual port-forwarding rules might be helpful.
And you thought that providing a sloppy problem description would
spread the joy more evenly?
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
"1" is popular. You seem to have covered "3".
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] You seem to have covered "3".
The first part, at least. But I don't recall seeing any complaints
about NAT loopback on the R6400v2, so I wouldn't expect problems with
that.
