- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6080 disable wifi on a schedule
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just installed R6080 AC1000. I cannot get the WIFI scheduler to work, there are a number of bugs:
1. When I set the time to 00:00 to 16:00, select it, and click apply it shuts off the wifi, but the wifi never turns back on. I have to turn it back on manually. That makes the function useless.
2. The next day, it did not turn off automatically.
3. I cannot delete the schedule I've created. I select the schedule and click delete. NOTHING happens.
Note: I upgraded to the latest firmware as of 9/3/22.
What am I missing? I hope someone can help!!
Thanks, Phil
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Spectrum service and modem are good for 300Mbs. Getting 89 with this router! Ugh!! I think I will solve my current problems by returning this hunk of junk. I think Netgear simply dusted off an old design with old chips to sell to the low end of the market, and possibly get rid of old chip inventory. It's also disappointing they ship what appears to be an unfinished/ un-debugged design!! I do have the spectrum router that works, so I'll go back to that for the time being, but they do not allow users to change settings or disable 5G wifi or anything like that, which was my reason for finding a router I can control.
Thanks for your help and suggestions! I'll mark this as solved!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6080 disable wifi on a schedule
Where are you doing this? In Set Up a WiFi Schedule?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
By the way, don't expect much from this router. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money. It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply! My firmware is V1.0.0.54. The router is connected to a Spectrum modem, model Hitron 2251. Yes, I'm trying to setup the schedule under "advanced wireless settings". Pic attached. If I select the schedule with the radio button and check "turn off wireless signal by schedule" it turns off the wifi. Also, when I try to edit or delete the schedule I cannot. The buttons do nothing. All of the other functions in other menus appear to work OK.
I'm using Firefox to access the router. I tried Bing, but Bing is so dysfunctional it won't let me type "192.186.1.1" as a URL. It just does a search with results telling me to type that number in the URL. SMH!
Also, thanks for the heads up of the wifi speeds. That will definitely be an issue for network operations.
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Simple modem and the newest firmware. So no issues on that front.
One thing you could try is to avoid 00:00 as the time. This can cause problems with "clocks" that are supposed to roll over midnight. Use 00:01 instead. Also, use 23:59 for any "off" switch.
That warning wasn't about wifi speeds. The router's 100 Mbps speed limit is the wired speed. The LAN port in your modem will be 1000 Mbps. So even if it connects to your internet service at anything faster than 100 Mbps, which is pretty common for cable Internet, your router can't use that speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I just realized that about the speed. I did a speed test... pretty bad!!
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Phil
How fast is the internet service you pay for?
If this is a new router, you might benefit from buying something a bot more capable.
I am amazed that Netgear made something that slow in 2017. 1000 BASE-T has been the standard for a decade or more.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Definitely. The R6080 is a handful dinosaurs.
Netgear routers with model numbers R60XX and R61XX seem to be "Fast Internet". (For "fast" read "slow".) Gigabit Ethernet kicks in when you get to R62XX.
One problem is that people see things like "WiFi—300+867 Mbps speeds" on boxes and assume that the router will work at that speed. It won't even achieve that for the wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for all your help... and candor!! Router has been returned! I will take a look at the model you suggest. Dang, I may have to spend some money!! LOL!
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wouldn't recommend any particular model without knowing what you want to achieve, what your traffic is and who uses it.
There are dozens of different models from Netgear alone. I have tried just a handful.
I don't believe in spending money for the sake of it. So I check what I want against the kit on offer.
My main router, the R7800, is ancient. But it is robust and is still favoured by experienced users who don't want bells and whistles.
I advise people to plug their your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Also think "budget". What do you want to spend? I am a great believer in buying last year's model. Things that brands and retailers want to shift. Think bargain, but not cheap.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
