× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6080
Lolo1017
Follower
R6080
Do you REALLY have to pay to speak to technical support?? Sounds sketchy, don’t trust it.
Message 1 of 3
Guru
Re: R6080
If you're outside of the 90 days of free support, yes it does cost money. Unless you have a total hardware failure.
Or you can use the community forum as its free on here as its people from the public helping out.
But we'd need a description of your issue, what you've tried, and your home setup.
(btw, that router is a pretty low performing 10/100mbps router)
Message 2 of 3
Re: R6080
This place is free.
But if you called someone you found with a web search, there is a high probability that it is a scam.
Message 3 of 3
Discussion stats
  • 2 replies
  • 451 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
