× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6120 Repeatedly gives error message when attempting to set up the guest network
thejohnsolo
Tutor
Just updated the firmware which caused the router to factory reset itself. When I got everything back up and running, I tried to turn on the guest network. Every time I do, it gives me an error message after trying to set up the credentials. I’ve rebooted (even unplugged) several times. Still getting the same error message.
Message 1 of 7
Guru
Re: R6120 Repeatedly gives error message when attempting to set up the guest network
What error message are you getting?
What happens if you use the default SSID name and a PW of Password123?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 7
Guru
Something to keep in mind with the R6120 is that it isn't gigabit. Its only 10/100mbps.
Most ISP's base level speeds have increased to over 100mbps speeds. Meaning if that's happened with you, the R6120 is bottlenecking your network and slowing you down. Its a pretty old/base model device.
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 7
thejohnsolo
Tutor
It doesn't give an error code. It just says "Configuration Error" and on the bottom it says, "The Router could not apply your new settings. Check your WiFi connection and try again." I have tried the default SSID, but not that password. Any ideas?
Message 4 of 7
thejohnsolo
Tutor
My ISP has increased our speed to 300, but does that mean that the router would have a problem with activating the guest network? If so, is there a way to fix it?
Message 5 of 7
Guru
You should still be able to activate the guest network.
but if you have 300mbps service, you need to upgrade that router.
Its not capable of speeds over 100mbps as its not gigabit. Its bottlenecking your network big time.
Message 6 of 7
For clarification, this is a reference to the wired LAN and WAN ports on the router. It has nothing to do with wifi speeds.
The manual says it all, well it would if it didn't have a mistake.
When it says:
LAN Four RJ-45 ports supporting 10BASE-T
WAN One RJ-45 port supporting 10BASE-T
it is actually 100BASE-T. (100 Mbps) That is slower than your Internet connection.
Newer routers have 1000BASE-T. (Even newer one are faster still.)
Even without an Internet connection, nothing on your network can travel through your router faster than 100 Mbps.
The surprise is that Netgear even sold devices as slow as this as recently as 2019.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 7 of 7
Discussion stats
  • 6 replies
  • 915 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
