- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6120 powerlight is flashing after bad update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Title says it all, basically I tried to update my router, and accidentally unplugged it while doing that. Now the green power LED is slowly flashing and the router is doing nothing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6120 powerlight is flashing after bad update
> [...] Now the green power LED is slowly flashing and the router is
> doing nothing.
And your Web/forum search for terms like, say:
Netgear flashing power
found nothing useful? Including, for, example:
https://community.netgear.com/t5/x/x/m-p/2121897
https://community.netgear.com/t5/x/x/m-p/2109843
[and a host of others...]
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sadly, unplugging the thing may have done serious damage to the router's firmware. The manual for your device will confirm that the flashing power light you see is a sign of corrupt firmware.
First see if this gets you anywhere:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The chances are low, but you never know, and you won't do any more damage.
If that fails, then try this:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
It is a more severe "recovery reset". If that works, and the power light stops flashing, then you may be able to so this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
If that fails, then this is the next thing to try:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to enable TFTP on a Windows PC.
TFTP isn't the easiest operation – it can take several attenmpst to get the timing right – so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
The good news is that TFTP has rescued many a dead device.
If that doesn't work, come back for other suggestions.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
