- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6220 - 5G max connection speed up 173mbps no 867 option availabe
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I can't seem to get my router to show the options that allow the 5g interface to offer 867 Mbps connection it currently only allows up to 173mbps
When I go to wireless setting under the Wireless Network (5GHz a/n/ac) setting it only gives me the option to set the mode up to 173mbps and there is no other options available.
Everything I have read indicates that there should a number of different options including "up to 867 Mbps".
What setting am I missing to get the router to allow me to try and connect at 867 Mbps?
Note: The Wireless Network (2.4GHz b/g/n) mode setting is setup to up 300 Mbps with Enable 20/40 MHz Coexistence ticked yes
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What region is your router set to? Someone else had a similar issue and their region was set to something like Israel. Perhaps there are region-specific limitations imposed by regulation.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6220 - 5G max connection speed up 173mbps no 867 option availabe
Thank you, that was it changed the region from Africa to United states and all the options appeared
