×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
R6220 - Can't set VPI/VCI
Barrytown
Follower
I would like to use my r6220 router and return my isp provided router. I have the PoE login and password from my provider as well as the ADSL settings. The ADSL setting is not in the genie set up, I can not get the router to connect. I have tried updating the firmware, but it says I'm up to date. I have version 1.1.0.34_1.0.1
I have looked in advance set up and VPI/VCI settings are not available. I'm not sure if this is what is keeping me from connecting or if its something else.
I'd appreciate any advice I can get at this point.
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 2
antinode
Guru
Re: R6220 - Can't set VPI/VCI
   What, exactly, are you trying to replace?
> [...] The ADSL setting is not in the genie set up, [...]
   Because you're trying to replace some (unspecified) DSL modem+router
with a (modem-less) router?  I think that I can explain that.
   Where did you intend to stick your phone/DSL wire?  (Hint: sticking
it into an Ethernet hole, where it doesn't really fit, would be a bad
idea, for multiple reasons.)
Message 2 of 2
Discussion stats
  • 1 reply
  • 501 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
