×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
R6220 Is there a means to disable the 2.4GHz transmission s while still using the 5GHz functions?
bobsch7050
I would like to disable the 2.4GHz transmissions while still using 5GHz because the 2.4GHz interferes with other electronics near my router. What I have been doing is pushing the WiFi on/off button on the router whenever I want to use the other equipment, which is inconvenient.
Model: R6220v2|AC1200 Smart WiFi Router with External Antennas
Message 1 of 4
Guru
Re: R6220 Is there a means to disable the 2.4GHz transmission s while still using the 5GHz functions
You can disable it but you might have better luck just changing which channel it broadcasts on.
Then you can still use it and reduce interference.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
wcalifas
Prodigy
You gotta log into your routers settings and go to the wireless section and it will show both bands being on, you have to click off "broadcast SSID"  when you're logged into it.
Message 3 of 4
bobsch7050
Tried it. Works great!
Message 4 of 4
Discussion stats
  • 3 replies
  • 585 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
