×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
R6220 can't delete allowed devices in the Access Control menu
jeyj
Follower
Hello.
I am using R6220 with the firmware V1.1.0.100_1.0.1.
Even before having the newest firmware installed, I made a list of MAC addresses so that the router would only allow the connections from the recognised devices. Although unware of from which version of the firmware this malfunction appeared, now I find that the list of MAC addresses isn't displayed correctly. Also, I can't delete the allowed devices. After selecting one or more item(s) in the list and then press deleting, nothing changes.
In the list at the moment, the names of devices display a lot of "&nbsp"s and the MAC addresses are indicated as ">" and "pan>". Moreover, when trying editing a "Device Name" in the list, I end up with the set-up page showing an error message "403 Forbidden", so nothing in the list changes.
Could you help me on this topic, please?
Kind regards,
Message 1 of 7
Tomhilson
Re: R6220 can't delete allowed devices in the Access Control menu
I am having the same problem.
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 2 of 7
Gooch20
I am having the same problem with the R6230, which I think is almost identical to the R6220.
MAC addresses for devices that are not currently connected look like this:
pan>
Sample of a screwed-up device name looks like this:
Roku Ultra (should just be Roku Ultra)
If I try to edit one of these odd entries, or delete it, I get a "403 forbidden" error.
Also, with the last FW update, all entries in the allowed devices table went from the default font to 'Courier'.
Model: R6230|AC1200 Smart WiFi Router Dual Band Gigabit
Message 3 of 7
Gooch20
Here's what the messed up device table looks like:
EDIT: I guess I can't post images yet. 😞
Message 4 of 7
Gooch20
I did a factory reset and started with an empty device table.  The problems still seems to be there.
You cannot edit devices that are not currently attached to the network.
This is a bug and Netgear needs to fix it.
Message 5 of 7
olympos1625
NETGEAR Employee Retired
Hi Guys,
Good day!
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. Are you still having this issue? Are using the latest firmware version for this model?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 6 of 7
Gooch20
Hi
I upgraded to V1.1.0.106_1.0.1 and the problem went away.
Thanks.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1181 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
