- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6220 stops routing between WIFI and LAN
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I using netgear R6220 wifi router. i have connected few devices using LAN: TV, Surveilance, and desktop computer, but computer is avalilable only if UPS is switched on.
TV is configured using DHCP, but Surveilance has set static ip = 10.0.0.125.
DHCP is configured to allow addresses 10.0.0.2 - 10.0.0.50.
router configuration is reseted to factory, and changed only LAN address, and DHCP address pool.
Problem is that, after some time, I cannot ping 10.0.0.125 (surveilance) from WIFI.
After router has been rrestarted and configured, it works for some time, and next morning I try to check surveilance video and ping not work...
I checked Wifi 2.4, and 5G.
I also updated firmwqare to last one.
Do someone know that problem, because I don't know if should I return router for seller or not.
Thanks in advance.
Peter.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6220 stops routing between WIFI and LAN
Hm...i will try, DHCP reservations bases on router config...
I will set it today and check.
Thanks for reply.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
