× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
R6300 V2 POWER SOLID RED
MDSTEWART1
Follower
The power led is sold red i have reset and done everything i can find online. Still nothing. Is it fried?
Thanks for your help in advance.
Message 1 of 2
Guru
Re: R6300 V2 POWER SOLID RED
You tried a factory reset? Pushing and holding reset for up to 30 seconds while its powered on?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 597 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
