- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6300v2 dropping offline regularly
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have this problem that seems to have begun with the last firmware update. On regular intervals, between 30 and 120 minutes, the router stops responding. I get no errors anywhere I can find them, and it's def not the cable modem as I ran for two days hardired to the modem and did not drop. I am at a loss as to how to even start troubleshooting this, as the logs and whatnot give me no indication that anything did, indeed, go wrong., Any help would be greatly appreciated.
R6300v2 Latest Firmware
Windows 10 on clients mostly
Windows 10 Pro on one machine
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @TristanX,
1. Please indicate the firmware version of the router.
2. Please make sure you do a factory reset every time you do a firmware update.
3. Does the connection drop on both wired and wireless connections via the router?
4. You can try changing the MTu values if the wired connection is affected. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6300v2 dropping offline regularly
I'm really frustrated by this, and just found out I have no support options as this was a replacement router for a previous one that failed. This is happening multiple times a day, every
single
day
This is unacceptable. I see a LOT of other customers are having this same issue, with no resolution, across multiple versions of your hardware. When are we going to see a resolution to this? this did not happen with this frequency or regularity until the recent security firmware update. PLEASE help, I do not want to have to throw this against the wall and get a different brand.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @TristanX,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
