× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
R6330-1AZNAS router works ok but does not show all users
Curtisb43
I just installed the R6330-1AZNAS . NETGEAR WIFI  (firmware updated) Nighthawk only shows 8 users, I can turn off each user, but my grandson is still on line with his android Tab-a (2016 I think)
What can I do to add it to the list and limit his on line time?
Message 1 of 7
Re: R6330-1AZNAS router works ok but does not show all users
What firmware version do you have on the device?
A number is more useful than "updated" or "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
Where are you looking for on-line devices? The browser graphical user interface (GUI)? An App (iOS/Android)?
Message 2 of 7
Guru
Are you doing it through the app or through the browser?
Check in the browser as the app isn't always accurate.
Message 3 of 7
Curtisb43
I installed this unit less than a moth ago. It connected to Netgear host and down loaded what was current then.  And did not show the grandsons unit I have his MAC number its not listed by nighthawk
firmware v1.1.0.88_1.0.1
Just checked to day and up todate
Message 4 of 7
Curtisb43
as using app.. did not know app was not the best
Message 5 of 7
Curtisb43
Just looked on I pad thru the router, his is listed  and it now shows  up on Nighthawk, but when I try to disallow access, it says "sorry that action failed, try again"  3 times
Message 6 of 7
Unfortunately, that is not the most reliable test.
In this case, the test is correct! No missing Hotfix.
Unfortunately, Mac addresses are also less reliable than they were. iPhones have taken to changing their Mac addresses more often than some of us change our socks. They are not alone in adopted a "random mac address" as a security measure.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 690 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
