Orbi WiFi 7 RBE973
R6350 How many devices can I connect
Rodrimag
Hi,
I have an R6350 and would like to know how many devices (wifi) I can connect.
I have approximately 30 devices connected at 2.4GHz and 8 connected at 5GHz.
When I try to connect a new one, I normally have issues, or when the router restart, some devices did not receive an IP address and I need to block this device to the others receiving the IP address.
Maybe I have many devices?
Message 1 of 8
Guru
Re: R6350 How many devices can I connect
Its usually 32 per band. but the R6350 is a pretty basic router. If you can move any of the 2.4ghz devices to 5ghz, you'll do better to even out the load a bit
Message 2 of 8
Rodrimag
So, it means 32 devices at 2.4Ghz and 32 devices at 5Ghz!!! So if I connect a second wifi router (this r6350 connect a second wifi router by ethernet cable), I can double the devices?
Message 3 of 8
Rodrimag
Message 4 of 8
Guru
If you've separated out the bands and made sure they're not on the same channel.
but again, its not a flagship router, its a pretty base model one.
While it should support up to 32 devices, if they're higher bandwidth devices, you're going to have issues.
https://kb.netgear.com/24043/How-many-WiFi-client-devices-can-my-NETGEAR-router-support
Message 5 of 8
Rodrimag
Ok, If I understood you, my router is a basic one, and my devices are simple IoT, like a smart switch, or smart lamp, these devices do not require higher bandwidth. So my idea is to connect a second router to increase the number of devices in my network. In my mind I will have 20 devices on my first router and more 20 devices on the second, my thoughts are correct, adding a router increases the device's number even that I sacrifice a little my bandwidth with a low investment.
Message 6 of 8
Guru
It should work. But put the 2nd router in AP mode.
Message 7 of 8
Does that increase the number of wifi cliemts it can handle, or does it all feed back to the router?
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1950 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
