×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
R6400 AC1750 Can't connect on Wi-Fi
paul-s-1056
Just got the AC1750 WiFi router: can connect via ethernet fine, but I can't get a WiFi connection to the router on either 2.4 or 5Ghz...I may have to go back to my Belkin WIFi-n model, at least temporarily, as I have a number of laptops scattered around the house, it's very inconvienient to bring them all to an Ethernet...
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 4
Accepted Solutions
paul-s-1056
Re: R6400 AC1750 Can't connect on Wi-Fi
I fixed the problem myself - I reset the router, then everything came up... I must'a accidentally turned off the WiFi portion of the router when I set it up the first time...
...although all the "normal" lights on the front panel were on, including both the 2.4 and 5Mhz ones...
Message 3 of 4
All Replies
Can you say a bit more about what is going on?
We can't read much from "I can't get a WiFi connection to the router" unless you tell us what you have done and where it fails.
You can find the user manual here:
NETGEAR AC1750 Smart WiFi Router Model R6400 User Manual
Maybe that will help.
Some more general stuff here:
R6400 | Product | Support | NETGEAR
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
paul-s-1056
Message 3 of 4
Stuff happens.
Message 4 of 4
Discussion stats
  • 3 replies
  • 5195 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
