LAA2
Dec 07, 2024Follower
R6400 WiFi router
Using NightHawk app to set up. At log-in, I repeatedly get a message that says login timed out. I have reset repeatedly. No luck. I know password is correct.
Try setting up with web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Try pressing the reset button for 15 seconds then release. Wait about 3 minutes then naviate to 192.168.1.1
I don't see the the r6400 on the compatible list for the nighthawk app.
You can find it here:
https://kb.netgear.com/000055505/Which-products-support-the-NETGEAR-Nighthawk-app
under this article applies to:
So the GUI/browser based setup might be the only option.
