- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6400v2 Choppy Calls & Some Devices No Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
The second issue is occasionally our iphones won’t be able to use the internet for a couple of minutes while we are watching the fire stick. The firestick never skips a beat but we often have to turn WiFi off and back on on the phones.
I have the following devices: iPhone 4ea, iPad 1ea, laptop 3ea, tv 1ea, fire stick 1ea, WiFi receptacle 1ea, and printer 1ea. There are only 2 of us at home 90% of the time and when we experience problems. We have identitified the problems still happen when neither of us is steaming.
I’ve had multiple people from Comcast test our cable and router including resetting with no change. I’ve also unpowered/repowered all equipment abd devices abd disconnected and reconnected dozens of times.
The first issue is a big deal because it may jeopardize continuing to work at home. Are there settings I can change or should I change out for a mesh system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400v2 Choppy Calls & Some Devices No Connection
Does it happen if you're hardwired into the router?
The goal is to determine if its a wireless issue, a router issue, or just a teams issue.
What firmware are you on?
What modem/gateway is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You got me thinking. On my lunchbreak I ran some tests using the following websites. The ring central doesnt have download/upload speeds based on the test I ran. I noticed similar jitters in the two different tests.
I not a wifi guy so I dont claim to know how good my tests were. I ran back to back tests. My guess is the jitter on wifi is causing the issue based on a REALLY small sample of tests. Doing reading it looks like jitter greater than 3ms can start to cause prolems with >20ms breaking the audio. I will try and run these tests when audio starts breaking again but the timing is really bad since I am usually in important calls when it starts breaking up.
Date | Connection | Location | Download | Upload | Jitter | Latency | Notes |
1/21 9PM | Wifi | Same Floor few rooms down |
| 60ms |
1/22 1PM | Wifi | Downstairs |
| 20ms |
1/22 1PM | Wifi | Next to router |
| 3ms |
1/22 1PM | Hardwired |
| 113 | 6 | 3ms | 30ms | Changed connection, tested internet, ran test |
1/22 1PM | Wifi | Next to router | 71 | 6 | 6ms | 30ms | Changed connection, tested internet, ran test |
| 119 | 6 | 2ms | 28ms | Changed connection, tested internet, ran test |
| 40ms | 31ms | Changed connection, tested internet, ran test |
1/22 1PM | Wifi | Next to router | 7 | 6 | 49ms | 32ms | Ran test a second time |
1/22 1PM | Wifi | Downstairs | 76 |
| 4ms | 30ms | Moved downstairs |
What should be my next step?
Also my router has the current firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What actual firmare version is it?
Do your testing on the 5ghz and not 2.4ghz. 2.4ghz is more sensitive to interference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem is a Arris SB6183.
I’ve been running 2.4ghz. I can do not ex testing on the 5ghz when I am working at home again on Friday (have to be in the office Tu-Th). I’ll post notes then.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
