×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
R6400v2 Half the speed on wireless wifi
JCXeeee
I recently upgraded Xfinity's 175mbps to 600mbps (I haven't done any speed tests before this, so I don't know if it was normal before). And I don't get the speed it should be on the wireless WiFi of the R6400v2 router (about 300mbps at 5ghz), but I get about 650mbps when I connect to the router with a cable. I've tried changing the channel, restoring the factory (firmware 1.0.4.126) but no change. I would like to know if this is normal and if not how can I fix it?
Thank you 😄
Message 1 of 5
Accepted Solutions
Guru
Re: R6400v2 Half the speed on wireless wifi
There isn't a fix for its. Its more of an expectation. Wireless isn't nearly as fast as wired (especially on wireless AC) and the R6400 is a base model gigabit device. hitting 300-350mbps over 5ghz is about what you can expect from it. You can read a tested review from the r6400 so you have some expectations for it. Keep in mind, in the test, its a controlled environment so it'll have a little faster speeds because there isn't interference and everything is optimized in SNB's testing.
https://www.smallnetbuilder.com/wireless/wireless-reviews/32812-netgear-r6400-ac1750-smart-wifi-rout...
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
All Replies
Guru
Message 2 of 5
JCXeeee
I appreciate you answering. But can a wifi 6 router run at full 600mps on wifi? If so, do you have any suggestions for a router below 200? Grateful!
Message 3 of 5
Do you have any Wifi 6 clients?
Your router can spit out wifi at a gazillion miles and hour, but if your wifi clients aren't up to it they will travel like bicyles.
As well as the review that @plemans linked to, this might also be worth reading:
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 5
janetwilson
Tutor
There isn't always a restore for its. Its extra of an expectation. Wireless isn't always almost as rapid as wired (in particular on wi-fi AC) and the R6400 is a base version gigabit device. hitting 300-350mbps over 5ghz is ready what you may anticipate from it. You can study a examined assessment from the r6400 so that you have a few expectancies for it. Keep in mind, withinside the test, its a managed surroundings so it's going to have a touch quicker speeds due to the fact there isn't always interference and the whole thing is optimized in SNB's testing.
Message 5 of 5
Discussion stats
  • 4 replies
  • 705 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
