- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6400v2 Router keeps dropping Internet Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400v2 Router keeps dropping Internet Connection
1. what firmware is on the router?
2. what modem/gateway is it connected to?
3. did this just start? has it been going on a while?
4. does it happen to all devices? Just wireless devices? Just wired?
5. Is IPv6 enabled? (if not enable and reboot the router)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
"The latest version" isn't always the latest or there could be a version with issues. Its why we ask for an actual version number you're on.
did ipv6 help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try downgrading the firmware a version or 2. I've seen reports on the .122 firmware of issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you go to the support site, click on downloads, then click on "view previous versions"
Download the one you want and extract it.
Then from there you follow the manual firmware update process but instead of using newer firmware, you use the one you downloaded.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your help. I went back to the previous version, in the middle of a new episode of Internet being down for wireless devices. The mobile app doesn't help, it often times out while I'm entering the password when logging in. It also didn't let me log in after the new firmware was installed, I had to use my laptop instead, it offered me to create a new password and that solved it. Now I'll wait and see if the latest firmware was the culprit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try go back to the time that you remember it was working okay. I have the same issue where the frequency of internet dropping is a couple times a day now that I have to reset my router everytime. and I had the latest firmware (v126). Now reading a couple threads of people recognizing the same issue, it was recommended to downgrade the firmware. So for me, it was working fine during 2021, now I'm back to v1.0.4.118 (which is around mid 2021 according to release note). Wish me luck!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
