Pwelch1
Jul 14, 2024Aspirant
R6400v2 not showing up in network list when setting up
Recently upgraded my spectrum internet with higher speeds, got a different router from them with 6e. Still terrible because the router and modem are far away and have to go through walls and doors to get to my pc, 5ghz barely connects and 2.4 is still bad. Have a R6400v2 from years ago try setting it up through the app but the step after it sets up the router and all the lights come on I have to connect to it through my network settings on my phone but netgear never shows up on my list of networks. All the lights on the modem and router are on, tried factory reset and no LTE on the phone still nothing.
Are you trying to connect the R6400v2 to another router?
If so, do you want to wire the R6400v2 to the other router?
If you want a wired connection then you should read the section in the manual Enable bridge mode.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.This is not something that you can do with an app. You need a web browser and the graphical user interface (GUI). This will work on a mobile device and its browser, just forget about the app.
- Pwelch1AspirantI am replacing the spectrum router with this one. Just want it to popup on the nwtwork list on my phone or pc so I can finish setting it up. Cant use wired
Pwelch1 wrote:
I am replacing the spectrum router with this one. Just want it to popup on the nwtwork list on my phone or pc so I can finish setting it up.It isn't easy to follow what is going on at your end.
What is this network list on your phone or pc. The SSID for the wifi?
What did the ISP supply?
A modem? Modem/router? Two separate devices?
I would be surprised if the R6400v2, based on a model from 2015, provided better wifi than anything recent. It certainly doesn't support 6e, but that needs wifi clients that can use 6 GHz.
