×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
R6400v2
khome
R6400v2
I have the nighthawk app on my phone. I always get into it to check setting and speed. Now when i open it, it wants me to put in the admin password. According to the website and the back of my router it says the password is password. Howver that does not work. It told me on the netgear website to go to routerlogin.net and reset the password. I do that and it gives me another password but that does not work either. when i try to login it just says Logon timed out, please try again, it persits try rebotting device. Well i have done that and i still cannot get past this log in. Any ideas???
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 4
Guru
Re: R6400v2
are you able to log in through the browser?
That should be the password it uses
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
khome
Re: R6400v2
Yes, I was finally able to log in by browser but I still cannot log on via app
Message 3 of 4
Re: R6400v2
Which one? Android? iOS?
Which version?
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 661 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
