Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR40 says offline but the internet is working
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-03
08:36 AM
2021-01-03
08:36 AM
I have the Orbi RBR40 with two satellites and the Fios wifi 6 router. They worked well and we had two wifi networks - but now the Orbi app is showing that the router is "offline". But, my Orbi network still works for the most part. The issue is that certain websites and apps on our phones do not work.
I have tried power cycling both the fios and the orbi but nothing has improved. Any suggestions?
Solved! Go to Solution.
Message 1 of 4
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-03
11:49 AM
2021-01-03
11:49 AM
its usually because you're using 2 routers on the network both in router mode. its called a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options?
1. put the fios in modem only/passthrough mode
2. put the netgears IP address in the fios's DMZ
3. put the netgear in ap (access point) mode.
use only 1 of those options to fix it.
options?
Message 2 of 4
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-03
11:49 AM
2021-01-03
11:49 AM
options?
options?
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-03
01:38 PM
2021-01-03
01:38 PM
Re: RBR40 says offline but the internet is working
This worked! Thanks so much for your advice - I really appreciate it!
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-04
05:14 AM
2021-01-04
05:14 AM
glad to hear it worked!
Message 4 of 4
Announcements
