× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RBR50 Orbi
Rar032
Follower
RBR50 Orbi
Is there a way to reset router if the RESET button does not work. It doesn’t click when I press on it. The power light does not turn amber after pressing for 20 sec. the button seems stuck. Is there another way to reset the router?
Message 1 of 2
Guru
Re: RBR50 Orbi
Try accessing the RBRs web page at 192.168.1.1 and use the ERASE function on the web page under Advanced Tab/Admin/Backup.
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 503 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
