- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbr50 and two satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbr50 and two satellites
what modem/gateway do you have?
What actual firmware version are you on?
You can view/download the latest firmware on the support site.
https://www.netgear.com/support/product/RBR50
the manual walks you through manually updating as well. If you go this route, do the satellites first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am not sure what you mean about modem/ gateway but we use point broadband as our internet provider as we stream our television viewing. One of the satellites is the Rbs 40v Orbi voice. I am not sure if that would cause the error message all the time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are up to date (as of today) but it might not be connecting to the server properly if you have a double nat issue.
It why i was curious about your modem/gateway
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its tough to help with minimal info. You wouldn't expect your mechnic to fix your car with only the info of "its a ford car" and when the machanic asks what motor is in is is told "its a motor just tell me whats wrong".
It doesn't work like that. There isn't a simple "fix it" button that corrects all problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Whenever I try to see if there are any firmware updates [...]
"try" _how_, exactly?
> [...] I get an error message [...]
What, exactly, does this "error message" say? Or is it a secret?
> Any suggestions as to why I keep getting the error message.
Without seeing "the error message"? No.
None of that is a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> I am not sure what you mean about modem/ gateway [...]
To what is the WAN/Internet port on the Orbi connected?
> [...] I would just like to know how to fix my problems.
Try a psychic hotline? Provide even a little useful information?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I apologize for not being a tech guru but I think your comments are a bit harsh. I will try to provide more information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please look at the box/device the router is connected to on the wan port. This should be your gateway.
It should have a model number
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem.
My RBR850 and satellites did an update using the web page "Firmware update" once to get to 3.2.17.12
Every week or so, I would "check for new updates" and be advised that no new firmware is available, however checking https://www.netgear.com/support/product/rbk853.aspx#download I found V3.2.18.1_1.4.14. I downloaded both versions (router and satellite) and did a manual update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
