× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ReadySHARE not permanent visible in windows 10 explorer, R7000
BenZ
Hello
I'am able to 'see' the two USB drives attached to my R7000 by 'running the \\readyshare command'.
I have to re-run \\readyshare command each time I open windows explorer while in the past I saw the USB drives permant in windows explorer.
This is inconveniant for making back-ups of those usb drives e.g.
thanks for any help
Ben
Message 1 of 2
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: ReadySHARE not permanent visible in windows 10 explorer, R7000
Welcome to the community, @BenZ
Did you try resetting the router?
I suggest that you try to safely remove the drives then factory reset the router then reconnect the drives and verify if the problem continues.
Message 2 of 2
All Replies
ElaineM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2931 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
