× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Region disabled after Wireless Setting 1st time
d4rrell
After I first setup my R6400/AC1750 I see in the Wireless settings the region is "Canada" but disabled.
I am able to setup a new SSID and password but after I apply this the disabled region dropdown is now reads "--select region---" and now if I try to make any Wireless setting changes I get the error message "please select the correct regoin for your location".
This is clearly a bug in the fireware and I have have tried couple firmwares all the ways to the latest V1.0.1.26_1.0.19.
PLEASE HELP, or I am returning this router.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 5
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Region disabled after Wireless Setting 1st time
Hi @d4rrell,
1. Have you tried resetting the router? If not, please do. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/9665
2. Does changing the timezone under Advanced > Security > Schedule make a difference?
Dexter
Community Team
Message 2 of 5
All Replies
DexterJB
NETGEAR Moderator
Hi @d4rrell,
Dexter
Community Team
Message 2 of 5
DexterJB
NETGEAR Moderator
Hi @d4rrell,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 5
tik_tok
@DexterJB wrote:
Hi @d4rrell,
Dexter
Community Team
I am having the same issue with the latest firmware for the R6400 wirless router. You are only allowed to make one wireless setting change before the region drop down menu is grayed out and region is revised to "--- Select Region ---". You cannot make further changes to region and applying changes to any of the wireless settings are not possible - a popup is displayed with the following message: "Please select the correct region for your location".
I have tried as you suggested to change the time zones - no luck. Region selection is still grayed out in wireless settings. The only superficial solution is to either perform the hard reset (as suggested) but once you change the settings one time the region is grayed out  again and no subsequent changes can be made. Also reverting back to previous firmware will fix the issue but once it is updated to the latest the problem is back.
I would think this is firmware issue. Does Netgear provide a submission form to report firmware bugs/issues?
Message 4 of 5
DexterJB
NETGEAR Moderator
Hi @tik_tok,
I have done my own test and did not encounter the issue. I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3839 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
