× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Router pr2000 n300 Trek bricked
pePaolo
Hi there, this is Paolo, I have a Netgear pr2000 trek bricked by wrong firmware, green power led working, green internet led working, green usb led blinking, sometimes green wifi led blinking.
ipv4 manual ethernet 192.168.1.1 no response, no ping fron cmd line...
Someone can help me on this issue?
Thanks
Model: PR2000 - Trek N300 Travel Router and Range Extender
Message 1 of 4
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Router pr2000 n300 Trek bricked
Welcome to the community, @pePaolo
What firmware did you use?
You may try re-uploading the correct firmware by following the link below.
How to upload firmware to a NETGEAR router using TFTP
Message 2 of 4
All Replies
ElaineM
Message 2 of 4
pePaolo
Elaine, Many thanks for your answer. I unsuccessfully tried many times this guide...
  1. Unplug all port connections from router except the PC you are using to upload.
  2. Turn router OFF for 10 seconds.
  3. Hold down the reset button on the back of router with a paper clip.
  4. Power ON the router while holding down the reset button.
  5. Watch the Power LED. It starts with orange color, and then will start flashing orange.
  6. Power LED will then turn to flashing green. Count at least 10 flashing green LED and release the reset button.
  7. Click Upgrade button on the tftp2 utility to do firmware upgrade
Is it good for any netgear router? The pr2000 trek has no orange led, but 4 green leds, and if I try tftp2 it goes in timeout.
and if I keep pushing reset and turn on the power of the pr2000 the usb green led starts blinking, but again tftp2 goes in timeout.
Nobody else with the same issue?
Message 3 of 4
ElaineM
If it can't be restored then it's totally bricked.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4243 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
