bmeana's avatar
bmeana
Follower
Aug 26, 2022
SMPT Email Camers
1 Reply
  • StephenB's avatar
    FWIW, you are posting this in the wrong forum area (this is for ReadyNAS, not routers or cable modems).
    Are you using an app-specific password in the camera and DVR for gmail?  Google changed their security settings a couple months ago, and I believe you will not be able to use your normal gmail credentials with the camera or DVR.
