× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
[Solved] Can't Change Security Settings on WNDR3700
RossB92
Hello,
I am trying to add a password to my WiFi security on my WNDR3700, but for some reason, I cannot. When I login to my router and attempt to change it, the setting won't even move. It's just stuck on "none" and won't move to any other type of security. I've tried resetting and unplugging and all the usual stuff but nothing seems to work. Any help would be greatly appreciated. Thanks!
Model: WNDR3700|N600 Wireless Dual Band Gigabit Router
Message 1 of 2
Accepted Solutions
RossB92
Re: Can't Change Security Settings on WNDR3700
Figured it out. Somehow my router had gotten put on repeating mode so I was unable to change the password!
Message 2 of 2
All Replies
RossB92
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2990 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
