× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Suddenly can't connect to NETGEAR57 (2.4), only NETGEAR57-5G (5.0)
DFA9
Tutor
I powered down the router (unplugged for 1 minute) and powered back up.  Now nothing connects to the 2.4 (SSID NETGEAR57).  Android devices not a problem as they connect fine to the 5.0 (NEGEAR57-5G).  However, Kindle devices are still trying to connect to NETGEAR57 (2.4) and get "Authentication Problem" error. There is no way to "override" the Kindle to connect to the 5G.  It finds the 2.4 when it scans for networks and only tries to connect to that. It does not "see" the 5G.
Nothing in my setup has changed.  Using the defaults that came with the router and have been for 2 years.  I upgraded with latest firmware (V1.0.1.4_1.0.52) and rebooted mulitple times.  Tried changing the password also.  Nothing works.  Is it time to replace the router?
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 5
Accepted Solutions
DFA9
Tutor
Re: Suddenly can't connect to NETGEAR57 (2.4), only NETGEAR57-5G (5.0)
WNDR3400v3. I did the factory reset and now all seems ok.  The only thing that changed after the reset was the channel on the 2.4 went from 9 to Auto.
Message 5 of 5
All Replies
Guru
Try a factory reset, and re-apply all the settings from scratch (that is don't reload a saved config file).
Message 2 of 5
DFA9
Tutor
How do I do a factory reset? I have no disc.
Message 3 of 5
Guru
You don't need a disk.  Usually there's a small hole where you insert a paperclip.  After the reset you'd go through the factory reset process.
Can you tell us what router model do you have?
Message 4 of 5
DFA9
Tutor
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5865 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
