oheli1
Mar 22, 2021Aspirant
Tagging/Untagging of Ports connected to ESXi-Host and APs (WAC729)
Hello Together,
Currently we have some really bad issues: the network is not stable an some Clients got the wrong IP-Adresses from a different VLAN. To eliminate setting-failures I couldn't find any clear answer in the manuals and now I hope you can help me :-)
1) How habe the stack-ports to be configured?
- We have 6 Switches (M5300 POE and non-POE) in Stacking Mode
- 12 Stacking-Ports are configured as Stack (Link-status: UP)
- Management VLAN-Id: 100
-> We untagged "U" all used VLAN-IDs on this specific Stackports (mostly Port 51/52 or 27/28)
-> And set PVID to VLAN-ID_1 (it is interesting, that some of these stack-ports still marked with "current PVID=0"
Question: Are these settings correct?
2) Switch-Ports which are connected to a ESXi-Host (10GB-ethernet ports)
- We have several VLAN which should all be available to the VMs in the ESXi-Host
- Mangement VLAN is ID-100
- it is clear that all used VLANs have to be "tagged"
Question:
-> Have these ports to be untagged "U" with Management VLAN (ID:100)?
-> or with VLAN-ID: 1 (default), or disabled (empty)
3) We have about 50 WAC720 controlled by a WC7600v2
- as mentioned before: Management-VLAN: 100
- Switch-Port which is connected to Controller has ID-100 untagged "U"
- Switch-Ports which are connected to a APs are tagged "T" with all used VLANs to be available in WiFi-Networks
- The management-settings for the APs are: VLAN: 100
- "Untagged Vlan" is disabled
Question:
-> Which PVID configuration is the right one for this AP-ports?
-> Have the Management-VLAN 100 to be untagged "U" for these ports
or with VLAN-ID: 1 or empty?
-> Or has the management setting "untagged Vlan" to be set to ID 100 and PVID also to 100 (as I understand the manual, this is only for initializing for new APs hat has to be changed after APs are initialized)
Thanks for you help in advance
Eli
- plemansGuru - Experienced UserYou'll get better help in the business class forum for your devices versus posting in the consumer->general router forum.
https://community.netgear.com/t5/Business-Wireless/bd-p/business-wireless-for-business- oheli1Aspirant
Hello plemans,
thank you for your tip.
I opened a new discussion in the business class forum, because I didn't know how to move or delete it.
Best regards
Eli
