× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Treadmill causes router to reset to factory defaults
bmellow2
I recently got a treadmill desk on which I put a TV, Blu Ray player and powered speakers.  I have had a problem where my router will reset to factory defaults if I use the treadmill more than about 20 minutes (just a guess, but I used it yesterday for 15 minutes and didn't have the problem).  The router is in the same room.  The blu-ray, TV, router and cable modem are all on a APC Smart-UPS SMT1000, but the UPS is on the same circuit as the treadmill.  I'm trying to figure out if this is a problem with dirty power or power sags or something else.
I am presuming the problem is the treadmill as I can't imagine the TV, Blu-Ray player or computer speakers causing the issue.  The treadmill doesn't have any wireless connectivity or anything like that.  It is very simple.
Do I need a filter before the UPS?
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 4
Accepted Solutions
bmellow2
Re: Treadmill causes router to reset to factory defaults
I am going to try moving the UPS to a circuit in another room using an extension cable.  There is only one circuit in that room.  I didn't have time to try that this morning.  I was just wondering if anyone else had seen this behavior.
Thanks
Message 3 of 4
All Replies
ElaineM
NETGEAR Employee Retired
Welcome to the community, @bmellow2
How about if you plug that treadmill in a different outlet?
Message 2 of 4
bmellow2
Thanks
Message 3 of 4
ElaineM
No problem. If it happens again, try to check other outlet which may be in a different circuit breaker.
To be honest, this is my first time hearing it.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3154 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
