×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Update
Cindyy
Follower
Update
I am having problems trying to update the Router. I can’t get my TV to come on until it’s updated. Please Help
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 3
Guru
Re: Update
What issues are you having?
Where is it failing?
You shouldn't need to update the router to connect the tv.
What issues are you having with the tv?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
Re: Update
You have posted your message in the section of this community given over to Mobile Routers, Hotspots & Modems. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
General WiFi Routers (Non-Nighthawk) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Don't expect much from the  WNDR3400v3. It has its origins in a pretty basic device device first launched in 2010.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Discussion stats
  • 2 replies
  • 451 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
