× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR 3400v2 Genie Utility software availability since it has been taken out of use?
putter63
Guide
I live in a rental house and the router is upstairs in someones else's apartment. My home PC crashed and I had to reinstall everything. I tried to reinstall the Genie utility but its no longer supported. Does anyone know if there is a way to find and reinstall this app/program?
Model: WNDR3400|N600 Wireless Dual Band Router
Message 1 of 9
Accepted Solutions
Guru
Re: WNDR 3400v2 Genie Utility software availability since it has been taken out of use?
If that took care of it, you can mark it solved so others aren't trying to "fix it" as well. 🙂
Message 6 of 9
All Replies
Guru
Do you need it?
You can manage the router through its ip address
You can download it here under the OS of your operating system:
genie | Product | Support | NETGEAR
Message 2 of 9
putter63
Guide
I used to know how to find the IP Address for my stuff but I can't remember. Can you walk me through please?
How do I access the router settings using the IP Address?
Thanks in advance!
Message 3 of 9
Guru
you can try and type routerlogin . net
or if you pull up a command prompt on your computer, you can type ipconfig
If you're not in a double nat, the default gateway will be the routers address.
How to Find Your Router’s IP Address on Any Computer, Smartphone, or Tablet (howtogeek.com)
Message 4 of 9
putter63
Guide
Awesome. Got it. Thanks for your help!
Message 5 of 9
Guru
Message 6 of 9
putter63
Guide
I've looked but can't find the button "Fixed" to click so that other members see that my issue has been resolved.
Can you help?
Message 7 of 9
putter63
Guide
Already done.
Message 8 of 9
putter63
Guide
Fixed. Thanks!
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1858 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
