× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
WNDR3400v3 Shows Connection for Shutdown PC
DERoss
Apprentice
I have a LAN through a Netgeer router (WNDR3400v3).  The LAN has two PCs connected via Ethernet cables.  The cables are connected to ports 2 and 4 on the router.
Why does the router show port 4 active when that PC is shutdown?
Message 1 of 3
Accepted Solutions
microchip8
Master
Re: WNDR3400v3 Shows Connection for Shutdown PC
Maybe because PCI Wakeup or WoL is enabled in the BIOS?
(PS: your router is ancient. Better upgrade to current standards)
Message 2 of 3
All Replies
microchip8
Master
Message 2 of 3
DERoss
Apprentice
That is it!  I had tried an application to wake my wife's PC from mine and mine from hers.  It never really worked as I wished, so I deleted it.  I forgot to turn off Wakeup in my BIOS.
Thanks.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 804 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
