- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR3400v3 - wireless devices connect to network but internet not working; intermittent issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hardware Version | WNDR3400v3 |
Firmware Version | V1.0.1.42_1.0.68 |
GUI Language Version | V1.0.1.24_2.1.28.1 |
When I first set this router up it worked great, but then started getting internet function issues. Wired devices are fine, but wireless will completely stop loading pages for minutes at a time.
Rebooting router seems to make no real difference; the wireless networks show no connection issues as far as devices connecting to the router but the internet just stops working sporadically.
I've updated firmware without improvement.
I tried a factory reset and ran with default settings (other than updating SSID/password) for several hours with no trouble for the first time in months, but the next day problems returned.
When I went back to Amazon and looked at negative reviews, I'm seeing this same complaint as the #1 review for this product.
Any suggestions? Should I start lobbying for a replacement?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDR3400v3 - wireless devices connect to network but internet not working; intermittent issue
Not sure when you purchased that device but it was originally released in 2010. I wouldn't be lobbying for a replacment device but in upgrading to a device in this current generations of products.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Phlegmbot wrote:
Hardware Version WNDR3400v3 Firmware Version V1.0.1.42_1.0.68 GUI Language Version V1.0.1.24_2.1.28.1
What modem sits on front of this ancient router?
Any error messages?
What wireless devices?
But, as @plemans says, this router, with its 100 Mbps Ethernet ports, dates back to 2010 and was never the most capable router available.
Does Amazon still sell it?
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree, it might be time to upgrade to a newer router. You can use that one as an access point, that's what I do with my older slower routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good call, but only if you are desperate to fill "not spots". The wifi on that aged router ain't gerat.
- Bookmark
- Subscribe
- Permalink
Yes, it's still under warranty and still on shelves for purchase at retail. I purchased it specifically because I don't need gigabit wireless capability for anything in my two person home. I just want a reliable and consistent connection even if it's only 20Mbs.
When having issues, frequently the admin page will show a "not connected" status for internet, even though webpages are working fine from wired devices. This is a symptom that was just reported by another user only days ago, but he states it was "fixed" by changing his password and he's not having further problems. Changing my password has not helped my situation.
Wireless devices include iPhone 6s, iPhone SE (the newer one), iPad, Roku, Chromecast, and a couple laptops. Issues remain even with all those devices unconnected other than just one for testing purposes (tried with different single devices).
If it would be a reliable hotspot, I'd be happy to use it for that and just buy an 8 port router... but I have zero faith that it would be any better that way since it's the wireless devices having troubles.
The modem is a Motorola MB7621, also purchased new, still available on retail shelves and Amazon, still specifically recommended by my cable provider, and functioning perfectly well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually, now I'm kinda wondering about just limiting the data rate for the individual connections to maybe 15Mbs or something to see if that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have never seen a Netgear "eight-port" router. Other brands maybe, but at a price, and they will all be GB ports. Four is the usually maximum. The easiest way to add LAN ports is a cheap switch. Mine is 16.
But not from Netgear. I guess there may be loads of old things lying around in the retail chain.
That looks like a decent modem. But you are throwing away some of its capability. The modem supports GB LAN. You may not have an Internet service that is faster than 100 Mbps, but your modem will still want to talk to the router as quickly as it can. It isn't just the single traffic stream that it handles. There is more going on than that.
Then there is the local traffic. If you have a couple of PCs on a network, they probably have GB ethernet and could hit the speed limit when talking to each other.
It is surprising that Netgear still sells 100 Mbps LAN devices,
- Bookmark
- Subscribe
- Permalink
Yeah, I have a switch for that purpose but figured if I’m being hosed by the router and not necessarily the wireless itself I could just replace that function. Not really necessary though.
@michaelkenward wrote:I have never seen a Netgear "eight-port" router. Other brands maybe, but at a price, and they will all be GB ports. Four is the usually maximum. The easiest way to add LAN ports is a cheap switch. Mine is 16.
True enough. I actually got this one at Target just because I wanted it quickly; I was fooled by the “Visit the NETGEAR Store” link and the features listing saying “Discontinued by manufacturer- NO” and didn’t consider it was an antique.
@Phlegmbot wrote:Yes, it's still under warranty and still on shelves for purchase at retail.
I also read in the ad that it’s gigabit WAN and 100 for the local side, which I really figured was adequate for my purposes. Appears that ad copy has now been corrected. Oh, well. If I have to get something newer to have a reasonable expectation of functionality I guess that’s what I’ll do. Just frustrating, especially in light of even new products reporting similar issues for some users. Luck of the draw, I guess.
@michaelkenward wrote:…There is more going on than that… It is surprising that Netgear still sells 100 Mbps LAN devices,
- Mark as New
- Bookmark
- Subscribe
- Permalink
That, and [other] users who have a hard time getting this stuff to work. We see a lot of "user error" here, from people who make the usual mistakes. (Modem/routers are a constant.)
Usually not the users' fault, the people who make this stuff can be their own worst enemies when it comes to user friendliness.
Remember, people turn up here because they have problems. For everyone who visits this community there may be hundreds, maybe even thousands, of people with no issues.
In your case, the strange intermittent wifi problems are a puzzle. You have a decent modem-only front end and a moderate load on the network. No obvious pinch points.
Did you ever say what Internet speed you pay for?
- Bookmark
- Subscribe
- Permalink
@Phlegmbot wrote:Luck of the draw, I guess....In your case, the strange intermittent wifi problems are a puzzle. You have a decent modem-only front end and a moderate load on the network. No obvious pinch points.
Was at 80 until I got an offer for 200Mbs for a lower price, which I was on until a couple weeks ago when I dropped it to 100 on a new lower price offer just because I don't use more anyway. I've never achieved a full speed connection outside of plugging a device directly into my modem and bypassing the router completely, and with the router it was still never over about 75Mbs to a single wired device within three minutes of a fresh reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using a 200 Mbps Internet service with a WNDR3400v3 router is just wasting money. The internet is twice as fast as your router can handle.
Even 100 Mbps for your Internet is unnecessary with a WNDR3400v3. As I explained eariler, that router can deliver nothing faster than 100 Mbps. And that is probably pushing it.
That 100 Mbps is promises has to handle all the housekeeping and traffic management. That wired connection also has to handle the wifi traffic. Just a few wifi connections at 20 Mbps, itself a athetic speed, will quickly overwhelm that "pipe". It all has to cram into the 100 Mbps that travels between the wire that connects the modem and the router. So that explains your top speed of 75 Mbps. It is designed into that ancient 2010 hardware.
Get rid of the WNDR3400v3 and buy something designed for the 21st century and you might be astonished by the difference. It might even get rid of the intermittent connection problems. Your slow router is inviting traffic jams on your network.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V• What is the difference between WiFi 6 and WiFi 7?
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
