- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR3700v3 Setup Guide
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can anyone point me to the correct setup instructions for WNDR3700v3? Netgear website links to Nighthawk app but the WNDR3700v3 is not listed as Nighthawk compatible. Nighthawk fails to connect to the modem as well even though I can see the wireless signal.
I basically just want to connect to wireless using this product. Other Netgear documentation directs me to enter the SSID printed on the product label .. there is nothing on the label that mentions SSID so I cannot connect to wireless. Is there not an easy step by step guide?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can set it up using the browser. The manual has the setup using the browser.
https://www.netgear.com/support/product/WNDR3700v3.aspx
the browser is usually how I prefer to setup routers anyway.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDR3700v3 Setup Guide
Thanks!
Looks as if I just need to follow page 2 of the installation guide using my laptop (no cd drive).
Was expecting I could access wireless using a default login then configure from there, but it does appear the router must be configured via a wired connection first.
And yes, I agree apps and wizards suck. Even if they work you never know what settings are being adjusted or required if you need to troubleshoot or fix anything. About half the time they fail outright and don't give any useful information on the failure.
