× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
WNR3500 keeps dropping the connection
Jazzsterre
Every 4 or 5 days my WNR3500L drops the internet connection and the wifi-connections.
I run with firmware V1.2.2.48_35.0.55 (the latest).
When I switch the power off and on again the router works again.
Can anybody give me some advice?
Message 1 of 18
Accepted Solutions
Jazzsterre
Re: WNR3500 keeps dropping the connection
Hi, it helped to downgrade the firmware version, as described above.
I swithed off the settings to install the latest firmware.
Message 18 of 18
All Replies
storm1985
Prodigy
is the issue both wired and wireless?
if wireless only - change the wireless channel - use NETGEAR Desktop Genie > WiFi Connect > Wifi Analytics
it will give u some recomended channel under Channel Interference tab
Message 2 of 18
Jazzsterre
It is both wired and wireless..
Message 3 of 18
ElaineM
NETGEAR Employee Retired
If you bypass the router, will you get a stable connection directly to the modem?
By the way, who is your ISP?
Message 4 of 18
Jazzsterre
Provicer is Ziggo (mdm is Cisco EPC3212).
This is mostly a stable connection.
The strange thing is that my Netgear has worked stable for about 2 jears (with same Cisco mdm), before this problems occured.
Message 5 of 18
ElaineM
Did you try to change LAN ports? How about trying a different Ethernet cable?
What lights are turned on when the problem happens?
How many wireless devices are connecting to the router? Are there any devices that may cause interference?
Try to reflash the firmware and reset afterwards.
Message 6 of 18
Jazzsterre
today it went down 3 times, wired and wireless. 5 wireless devices were connected.
Message 7 of 18
Jazzsterre
I cannot find the firmware for Europe, only for North Amerika. please help...
Message 8 of 18
ElaineM
Here's the link.
Message 9 of 18
Jazzsterre
thanks for the link. I just reflashed the router and will monitor for the next days..
Message 10 of 18
ElaineM
You're welcome. Feel free to give us an update anytime.
Message 11 of 18
Jazzsterre
Hi, I reflashed the firmware yesterday, but this morning the router hung again.
Powerled is green, i-led is green, wifi is blinking blue, direct lanport is orange.
http://www.routerlogin.net. was not accessable with any system (wired and wireless)
When I recycle the power everyting works 'normal'.
Message 12 of 18
ElaineM
Did you experience this before upgrading the firmware to the latest version?
How about if you downgrade the firmware?
See this link to downgrade the firmware. Look for firmware version 1.2.2.44 (All regions except NA).
Message 13 of 18
Jazzsterre
Hello, it is me again 🙂
I have read your solution, but just before I down-graded the firmware version, I noticed that www.routerlogin.net was blinking on the right part of the screen. It took about 3 minutes before i could select the upgrade section.
The powerlight was continuous green.
The internet was blinking green.
The wireless was blinking blue.
The LAN-port was blinking orange.
Maybe helps this information to detect the problem of my router.
I will inform you if the firmware downgrading gives a stable situation.
Message 14 of 18
ElaineM
@Jazzsterre How's the connection so far?
Is the power light continuously blinking?
Message 15 of 18
Jazzsterre
Hi, the connection is stable for over a week now.
Thank you for the support!
Message 16 of 18
ElaineM
@Jazzsterre What made it work?
Message 17 of 18
Jazzsterre
Message 18 of 18
Discussion stats
  • 17 replies
  • 5206 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
