- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Extender, from where?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
After purchasing one of these, I decided to try a wi-fi MESH solution.
This solution was NON-Netgear.
However I am using this ac750 to extend the coverage of it.
My question is will this device extend the strongest signal or the closest signal?
Clearly they are not always the same.
All mesh repeaters have the same SSID (the netgear device has a seperate one).
Apprecaite any further clarification questions or responses.
regards
Lethal57
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Extender, from where?
In theory it should connect to the closest one. In reality, we haven't always found that the case.
thats why we usually recommend that using the compatible satellites because then there's something controlling what that satellites connect to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Plemans,
So what you are saying mirrors my initial thoughts. shame.
BTW, the issue isnt one of what the 'satelites' connect too; Its one of what the Netgear device connects to of the satelites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
correct. I understand that its not choosing the correct satellite to connect to because the satellites use the same ssid.
I've seen it happen with mesh extenders as well since they don't have a router controlling which they connect to.
