Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi very slow on RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-09-03
10:54 PM
2021-09-03
10:54 PM
When I go in via my ISP's WiFi, I have top speed at Ookla speedtest. When I go over the Orbi WiFi, I'm only at 4Mbps down and 6 Mbps up Macbook, iPhone, Android). The Orbi App is also showing top speed but i think the apo is testin via Lan cable.
I also turned off the ISP's WiFi, but it didn't help much. Firmware are up to date. I have a RBR20 router and 1 satellite.
In the old apartment I had no problem. Also tried with a factory reset. But still very slow wifi. LAN (Sonos audio and TV are good) just Wifi is very bad.
Can‘t connect to 192.168.1.1 but if i go to the Routers IP that is showing on the ISP interface i can login with my old password (after factory reset) but on the webInterface is nothing I can do just check connected devices. So i think i have only the app on the phone.
Any Ideas?
Any Ideas?
Solved! Go to Solution.
Message 1 of 2
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-09-03
11:12 PM
2021-09-03
11:12 PM
Think, I just found the Problem. I removes the Sonos LAN from the Routers ethernet port and now I have full speed on wifi via orbi.
Message 2 of 2
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-09-03
11:12 PM
2021-09-03
11:12 PM
Message 2 of 2
Announcements
