× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Wireless device ip address shows as --
spacely
I went to connected devices and there's a wireless device that has dashes all across-the-board: the name the IP address, everything. Does that mean there's an intruder?
Message 1 of 8
Re: Wireless device ip address shows as --
@spacely wrote:
..... there's a wireless device that has dashes all across-the-board: the name the IP address, everything.
Dashes all across-the-board? Do you mean that the details are hidden?
Where are you looking to see this?
If you mean the Attached Devices page in the browser graphical user interface (GUI), what happens when you click on this entry?
Hard to tell without more information. If you can f9nd the Mac address you can begin to work out what it might be.
You don't tell us anything about your Netgear equipment. I assume that this is a router of some sort.
Message 2 of 8
spacely
It's a R6200v2. Yes, the connected devices GUI. Nothing is clickable, just dashes. Here's the cut 'n paste below ... and now there are even more dashed entries:
Wired Devices
#IP AddressDevice NameMAC Address
1192.168.1.13G77PCQ13E34:48:ED:A8:36:55
2192.168.1.16David78:E3:B5:B7:71:E5
Wireless Devices (Wireless intruders also show up here)
1----1E:E7:CE:18:94:9F
2----96:B9:F3:CC:38:DF
3192.168.1.3blink-sync-module74:AB:93:2A:89:20
4192.168.1.9David-s-S10eEA:0D:9B:98:1A:A0
5----00:D2:B1:4B:D7:85
6----BA:F0:6C:FD:71:25
7192.168.1.10LGwebOSTV64:CB:E9:8B:24:CE
8192.168.1.443TCLRokuTV10:3D:0A:08:4F:BB
9192.168.1.2Rokulivingroom20:EF:BD:4F:59:DD
What does "f9nd the Mac address" mean??
Dave
Message 3 of 8
What firmware version do you have on the device? Newer firmware may have changed the GUI.
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
You are not looking at the Attached Devices page. That has the editable entries.
What you see probably includes devices that were connected to your network, but aren't there any more.
Try roaming around in the Access Control area.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Allow or Block Access to Your Network.
Every device that connects to your network has a unique Mac address. The first bit if it will tell you who made the device.
MAC Address Lookup - MAC Lookup Online
This can help you to track down what it is.
Message 4 of 8
spacely
My router shows the firmware version:
Firmware Version
V1.0.3.12_10.1.11
The download page seems to imply I am up to date?
https://www.netgear.com/support/product/R6200v2.aspx#download
And I definitely am looking at the attached devices page... nothing clickable.
All but one of those dashed MAC address searches were not found. One I believe is a smart display my daughter brough home from college.
Do you think I should download the Genie App? I have it already, maybe it's been updated? I think Norton is blocking my download so far...
I tried to have the interface check for firmware updates, but it just kept flashing:
Attempting to connect to Netgear Server. Please Wait...
Message 5 of 8
Firmware Version
V1.0.3.12_10.1.11
Yes. That's the only way to do it. One recent message was from someone with what they thought was "the latest", but it was actually a year old and four versions behind the newest.  Hence the need to check.
It depends on what you mean by the genie app. Over the years, Netgear has put that label on various things. I am a fan of the desktop genie for Windows. (There's also one for Mac.) Netgear wants it to die, but some of us persist.
It is there on the downloads page for your router, but that link seems to be broken, which may explain what you see.
It is also here:
genie | Product | Support | NETGEAR
That has a very useful Network map.
There is something odd about your model. It does not appear on either of the "supported devices" lists:
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
Which NETGEAR home router models can I manage using the NETGEAR genie app? | Answer | NETGEAR Suppor...
Message 6 of 8
spacely
So you feel no need to update firmware, and no fancier GUI exists... and the dashed MAC's are just phantoms of previous connections... not to worry...?
Message 7 of 8
You should always update firmware, expect when it causes problems. If that happens you can roll back
For the phantoms, there are ways of keeping an eye on alien invaders. My line is that I investigate where those unrecognised entries come from before I get scared. Sadly, that takes a bit more local research rather than a question in a place like this.
If you are the sort of person who gets twitchy about Internet security, plenty of people will sell you fancy subscription solutions. I rely on common sense and the increasingly severe protection that comes with Windows, browsers and my Internet service provider.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1664 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
