× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Your Connection is not Private
chas1025
Tutor
I updated my system last night, now no matter what I do I keep getting the Your connection is not private.  I have rebooted several times and occasionally the system will work for a few minutes, then goes right back to conneciton not private.  I have the same outcome on both Safari and Chrome browsers.  I have a secondary network as a backup.  Any info would be appreciated.
Thanks
Charles
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 7
Guru
Re: Your Connection is not Private
What is this secondary network and how do you have it setup?
Is it causing a double nat?
https://kb.netgear.com/30186/What-is-Double-NAT
Message 2 of 7
chas1025
Tutor
My backup network is part of the Xfinity router/X1 system.  It has always been there for the 3 years I have run the Orbi system.  Never had a problem before.
Message 3 of 7
Guru
And sometimes updates either of the xfinity system or the orbi start having issues with the cascaded routers.
you're going:
X1--->orbi
Is that correct?
have you tried using the orbi in access point mode or putting the orbi's ip address into the X1's DMZ?
Message 4 of 7
chas1025
Tutor
Yes, did not change anything.  I am concerned something about the Orbi update caused the problem.  There was no Xfinity update recently.
Message 5 of 7
Guru
Or putting the orbi in access point mode?
Message 6 of 7
chas1025
Tutor
I figured out the problem,,,and it was simple.   For some reason, the parental controls paused every device in the house on the Orbi network.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1643 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
