× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
can't change timezone on R5060
newmguy
Guide
I have read that the timezone setting is under Advanced/Security/Schedule. However schedule is greyed out. Any advice?
I set the unit up as an access point only and I want to turn off the wifi at night. The time is in pacific time, I am on eastern time.
Model: R6050|A750 Wireless Dual Band Gigabit Router
Message 1 of 3
Accepted Solutions
Guru
Re: can't change timezone on R5060
Not 100% sure this will work, but you could try switching back to router mode to set the timezone.  Then switch back.
A workaround is to subtract three hours to the times in the schedule to compensate ...
Message 2 of 3
All Replies
Guru
Message 2 of 3
newmguy
Guide
Yes I already tried that last night, its working. Thank you
Switching back to router then back again worked, however it was difficult to login afterwards. I had to try  2 -3 times.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2953 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
