×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
how to turnoff firewall of the orbicable modem router model CBR750
deeboy
Follower
Message 1 of 2
antinode
Guru
Re: how to turnoff firewall of the orbicable modem router model CBR750
   What "firewall"?
   General advice: You might have more success if you described the
actual problem which you are trying to solve, rather than asking how to
implement some particular "solution" ("turnoff firewall"), which may
have little or nothing to do with the actual problem (whatever it might
be).
   What did you do?  What happened when you did it?  As usual, showing
actual actions (commands) with their actual results (error messages,
LED indicators, ...) can be more helpful than vague descriptions or
interpretations.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "firewall".
Further reading might not hurt, either.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 315 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
