×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
loss of signal
Ametuer
Follower
loss of signal
We lose our signal (cable) 3 or 4 times a day.  I remove the power supply to the router and it will reset.  I don't know or how to tell if I have a problem with the router or the incoming signal?  Is there a way I can determine which (if either) is the problem?  When I say we lose signal I mean the computer and TV's go off and say no signal and the computer says ( no internet).  They will be ok for a while after reset and then it has to be done again.  Can someone give me advice on what might be the problem?  Thank you in advance for your help.
Model: C6250|AC1600 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: loss of signal
If you take a screen snip of the cable connections page and the event logs, that helps us to check the line.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 431 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
