× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
need to temp disable 5ghz R6400v2 — AC1750 Smart WiFi Router 802.11ac Dual Band Gigabit:
SusanMarieb
Follower
I purchase the Atomismart wifi Stringlights and to install them they only work with 2ghz.  They say to disable the 5ghz mode so it can connect. then once the lights are connect re-enable the 5ghz.  I dont know how to do this.  Thank you
Model: Dual Band
Message 1 of 2
antinode
Guru
Re: need to temp disable 5ghz R6400v2 — AC1750 Smart WiFi Router 802.11ac Dual Band Gigabit:
> [...] I dont know how to do this. [...]
   Here's a radical concept which helps some people:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for
"Control the Wireless Radios" and "Enable or Disable the Wireless
Radios".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 701 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
