× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
problems using Netgear19 router on starlink network
gregpace67
Good morning, people. I have a problem that I cannot work out...
I live in rural NSW, Australia,  and have set up a Starlink System on our farm. due to the trees, we have found it necessary to install the dish ( square model) on the roof of our Farm-stay which is about 150m away.
we were originally running a system that had ADSL2 running to our main house, then the signal was transmitted wirelessly to the farm-stay residence, then the Netgear router was installed there and everything worked fine.
Now, I've installed the Starlink down at the Farm stay, I also installed the Starlink Adapter, and basically reversed the system, bringing the Netgear router back to our house, and trying to use THAT as our Access Point to the Starlink network
Now, when trying to set up the system, I've run into the problem that I have "no internet"
1) I have the ethernet cable plugged into the "Internet Port' on the router
2) all lights on the Netgear router are green
3) My Starlink App shows me that the router (and also my laptop, when I log into the router) are connected to the Starlink network
4) the Netgear Genie set up window will SOMETIMES show that I have internet, but any devices connected to the router show "connected without internet"!
Not being a very computer savvy individual, this kind of problem appears to be way above my pay-grade.....so ANY help VERY much appreciated!
Message 1 of 12
Accepted Solutions
Guru
Re: problems using Netgear19 router on starlink network
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
Message 12 of 12
All Replies
Guru
What model NG router do you have? R####, RAX?
Message 2 of 12
gregpace67
Model is WNDR3700v4
I've also tried a nighthawk AX5, and still the same problem
Message 3 of 12
Guru
Have you tried a Gb lan switch in between there modem and router?
Message 4 of 12
gregpace67
What is a GB Local Area Network switch?
Message 5 of 12
gregpace67
Do you mean use this INSTEAD of the Netgear Router?
Message 6 of 12
Guru
In between the modem and NG router:
https://www.netgear.com/support/product/GS105.aspx
Message 7 of 12
gregpace67
Could it be anything to do with the AP settings? Should I use a Fixed IP address?
At the moment it is:
IP address 192.168.1.86
IP subnet Mask 255.255.255.0
Gateway IP address 192.168.1.1
Primary DNS 192.168.1.1
there is no secondary DNS address
Message 8 of 12
gregpace67
What would be the expected operation of this device to assist in having the internet recognised by my devices attached to the network?
Message 9 of 12
Guru
Assists in the inter connection between starlink and your router.
It's recommended to contact Startlink for there help and information regarding connecting something up to there services.
Message 10 of 12
gregpace67
Thanks, I've sorted out the problem. It was the sender units that I was using to transmit the signal wirelessly. I was told they were multi-directional, but they're uni-directional. So I swapped them over and the system works! Cheers
Message 11 of 12
Guru
Enjoy. 📡
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 4416 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
