- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
r63002v2 slow speeds on 5ghz only
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had a r6300v2 fo quite a while and have not had any problems with it. However recently with no noticable reason the 5ghz network started running very slow. My i have 60mbps download speeds from my isp but on the 5ghz band I only get around 15mbps. In the past I have been able to achieve the full 60mbps on 5ghz. The 2.4 ghz seems to be just fine. I also checked to make sure other devices weren't the problem, and my network was the only one on channel 161. I am using firmware version V1.0.4.6_10.0.76
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @mrkwanzaa,
You can try doing a firmware reflash then reset and reconfigure the router. The links below may help you out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: r63002v2 slow speeds on 5ghz only
Hi @mrkwanzaa,
1. Have you tried changing the wireless channel for the 5GHz band just for isolation?
2. Does the issue persist on all the devices that connect to the 5GHz band?
3. Have you tried resetting the router?
4. Have you tried changing the mode?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DexterJB About and hour after the factory reset, I noticed that my speeds seemed pretty good and ran a test again. After changing to an open chanel (but one I had previously tested on) I got the speeds I was looking for.
Thanks for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry about this, but a few minutes after posting I found speeds were very slow again. I;m extremley confused and any help would be great
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @mrkwanzaa,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rolling back to firware version V1.0.3.2_1.0.57 fixed my problem. Thanks!
