× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
restore on R6400V2
KLAUS6622
restore on R6400V2
I have TWO R6400v2 routers.  Can I skip the tedious task of copying each and every setup parameter by just restoring the correct and tested backup from one router to the next?
Message 1 of 3
Accepted Solutions
Guru
Re: restore on R6400V2
If they're the exact same versions and models, yes. If they're different, then I wouldn't.
Also, if you're having issues, I wouldn't either as problems in settings can be carried over through backups.
Message 2 of 3
All Replies
Guru
Message 2 of 3
KLAUS6622
YOU ARE CORRECT!  Thanks.  Saved me hours of work.  Only thing I forgot to do is upgrade firmware....it also has to be the same.  🙂
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1787 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
